Abit fatal1ty an8 sli post code 7A
Elvis Ma
hey guys,
do any of you know what that code means(7A). i had this system up and running before but now that its in a new case its giving me problems :(. At first i installed everything and turn on the computer and it ran fine. then i realized that i didnt plug in the power for the CD Rom. so i shut down and plugged it in. then when i tried to power it back on, the motherboard didnt post, giving me an error (code 37 which tells me to test DMA channel 1). so i took out and reseated my ram, tried using 1 stick (im using 2x512) and placed the ram in different slots...nothing worked. so i cleared the cmos and that seemed to fix something. now it'll take me to the press del to enter setup screen but hangs up on error 7A (detect and install co-processor). any help will be awsome cause im outta ideas. thanks guys.
heres my system specs:
AMD X2 3800
xfx geforce 7800GT xt
1GB(2x512 corsair xms pro series cl2)
250GB seagate baracudda
Take the CDROM off of the boot list in BIOS, and see if that works. All you did is get a new case? You may have forgotten to plug some cords in on the mobo, but first check out the boots.
Make sure the tertiary power connector on the mainboard is connected (the Molex connector at the bottom of the MB)
check to make sure you didnt leave any standoffs in behind the board that may be shorting it out. like the one up next to the IO shield that this board dosent use.
