I have an ABIT AN7 board with 2 x CMX512-3200LLPRO Corsair XMS Pro modules and a MSI NVIDIA GeForce FX5700 video card, amd 3000+. I have unplugged everything else.
The Problem I am having is that I am not getting a post, I have swapped video cards with a known good video card which was a PCI video card. I have tried different ram which I know is good. I have also put in an AMD 2800+ from another system that works.
All I get when I power up is a blank screen, no memory activity, I know that because of the XMS ram has led's which show ram activity amd no video BIOS. I get a post LED code on the board of 9.0. Yes I looked in the manual for that code, and there is nothing about it.
I believe it might be a BIOS problem, but every attempt I have made to reflashed the BIOS has not worked. The reason for that is because it is a BIOS problem is that I have an older ABIT board that at one time show the same problem and by reflashing the BIOS I was able to fix the problem.
Any advice would be very helpful.
Thanks You,
waszo
Thanks You,
waszo
