A8N32 Help
reswob
So I've been running what's in my sig for about a while now and wanted to doa legit BIOS OC. I OC'ed it using AI Booster to 2.83ghz on stock voltage and air and it's been running fine.
I wanted to know how do I OC it in my BIOS for I want my ram to run as fast and tight as possible.
I go into CPU configurations, but I can't figure out how to edit my FSB and such. I can only change memory settings.
The board originally came with BIOS 1103 but I flashed it to 1303 using the software.
Thanks.
I think its under Jumper Free Config. Make sure you disable AI and it should enable you to change those settings. (They are grayed out if AI is on)
I have the Premium version so it might be different.
Alright, thanks! Now I have to go read more on OCing ram.
