A8N-SLI, second slot?
Status
Not open for further replies.
ilkhan
the top x16 sized slot on the -SLI is the primary, and that is where ny 7800GT is being installed to. But the cooler for it is a double slot. Im going to be running a highpoint 2320 as my raid card, with seagate SATA drives in raid 5.
If not running SLI (which sets each to x8), what speed does the second slot run at. And therefore, should I put the controller in the x16 sized slot or the x4 slot (its a x4 card).
Need an answer ASAP, as Im ready to put the card in *now*. Many thanks for any reply.
runs at x1 AFAIK, but I would reccomend flipping that card, because your 7800GT isn't going to get any slower.
No replies here made me actually look in the manual :eek:
You are correct, runs at x1, so I put the raid in the x4 slot, first power on had the arctic silencer fan hitting one of the sata ports, so I stuck a small peice of foam in between them. Airflow isn't compromised, and I'll get full speed from the raid.
Status
