A8N premium SATA issues, boot disk failure?
Deadsexy
I've been wrestling with my a8n premium for a few hours now and everytime I do the windows install on a SATA drive whether its 2 of them in raid0 OR a single drive connected solo once windows gets through the initial install and I reset I can never again get the drive to boot. I get "boot disk failure, insert system disk and hit enter" and I cant for the life of me figure it out. I've tried booting from my IDE storage drive and that works fine and once in windows the sata drive shows up with all the windows files installed along with all the files left over from my initial bootup into windows(where I enter my cd key ect...).
Once I enter my cd key and reset I can never again boot from the drive. The drive shows up in bios fine but just wont boot. Anyone have a clue as to what I am doing wrong? Perhaps a bios option not set correctly or some shit? I am stumped, might try the asus support forums but they seem kind of crappy so maybe I'll just call asus next.
FYI my components
asus A8N premium
3700+ sandy
memory(mushkin black, redline, and some ballistix...having a seperate issue here with memory...)
36gb WD raptor sata
40gb seagate something or other IDE drive
ocz powerstream 520 PSU
bfg 7800gt OC x2
SB audigy 2 zs
thanks in advance for any help anyone might be able to lend
tech support told me I need to press F6 during the beginning of windows installation and install some controller drivers just to use a single SATA drive despite not using raid. I've never seen this before and am skeptical it will fix things since I DID do that when trying to setup the raid0 array and still got the same error during boot but I'll try it anyway when I get home.
you don't need to F6 during your windows install. just skip pressing F6 and windows sill still load without sata drivers.
as far as your problem, did you try a different sata cable? your single drive needs to be connected to sata1 port not the raid ports. if it loads windows but can't boot - sounds like bad cable or bad hard drive maybe.
I just disabled the sil controller all together and things are a bit smoother. Upon windows initial install I get a missing system file(hal.dll) and the drive still wont boot but I get further down the pipe now. Gonna try new cables/drives now and see how much farther that gets me.
I disabled the sil controller because I remember reading that and the marvel lan share bus with something else so I just shut them both down and I'll stick with the nvidia stuff. Just had to install the storage device driver for the nvidia raid.
you don't need that raid driver for sata. what os are you installing?
The A8N SLI Premium has 8 sata ports there are no specific raid ports on this board.
If you are going to stripe or use some type of raid as your boot drive use the Nvidia sata ports the ones on the right. The nvidia controller has the raid options within the bios menu adjust accordingly prior to installing xp or win2k. If you are using the sil3114 controller the 4 on the left hit f4 when prompted after posting. Set your options in bios correctly follow the manual if you need some guidance. Plug your 2+ drives in order same as a regular IDE or pata setup so plug your two disks into port 1 and 2 not port 1 and 4 they are clearly labeled.
Remember to enable to nv raid in your bios! set the options :)
did you try to fdisk the hard drive and then run windows set up? I've had harddrives many times just have bad allocation tables or file structures present on there already so i just fdisked them and then they worked fine. If that doesn't work have you run a har drive test on it at all?
The tech support guy said the left ports where the nvidia sata ports so appartently I was plugging the sata cables into the very controller i was disabling each time. Once I got that sorted out i was able to get an OS on the drive but I did in fact have to install the storage driver for the nvidia controller, not just the raid driver. All seems well now and its on to troubleshooting my memory woes.
