a7n8x-x bios updating problems
senoryason
I am trying to update my bios so that dual-channel memory will work. I have the 1004 version of the bios, and when I try updating to anything above that, it either freezes while it reads the new BIN off of my floppy (in AWDFLASH.EXE) or it gives me a CheckSum error, telling me I can not update. I would rather have the latest version of my bios, but it does not seem to be updating...If anyone could help me please do.
Thanks
You should be very carefull updating your BIOS with the problems you are having. If the flash goes bad your system may not boot at all and you would have to get a new pre programmed BIOS eeprom chip. You could try the ASUS windows BIOS flasher and not rely on your floppy drive. Also just for your info the A7N8X-X does not support dual channel memory.
