natermeister
- Dec 26, 2005
I'm currently saving up for a pair of NEC 2690WUXi2 monitors. If I buy one SV model and the other in standard form, there is nothing to stop me from using the color calibration gear on the other one, correct? It's similar to other color calibration systems you see advertised in photography magazines?
I also intend, eventually, on buying a 3090, so I should be able to use the SV gear on that as well, correct? And yes, I measured my desk and it's just big enough for all that panel space.
Thanks,
-Nate
Thanks,
-Nate
