Bender_Unit_22
- Feb 21, 2002
ok all I am trying to do is use ghost to transfer the system drive to a different HD
I get it transferred, fix the hal.dll/boot.ini error caused by it being on a different partition number
I think everything if good then it hangs at the windows screen, it should say loading preferences but instead it just sits, then finally tells me...
a problem is preventing windows from accurately checking the liscense for this computer
so I hook the old drive back up and after googling it find out its probably caused by the change in the system drive letter
I tried the reg edits that various websites suggested but had to give up so I could still get 4hrs sleep
problem is it won't let me change the drive letter assignment thru windows
what is the best...easiest way to fix this?
