FBR_BDavis
- Apr 5, 2008
I'm newly registered around here, but have been browsing the forums for quite a while.. I asked pretty much the same question on the ASUS boards with little to no luck in receiving any helpful replies.. So, I'll give it a whirl here.. I'm not looking for a wizard to wave a wand and give me every step to OCing, but, a little assistance or pointing in the right direction would be greatly appreciated..
First, my system specs:
ASUS Crosshair Motherboard
AMD 6400+ Black Edition
Thermalright Ultra 120 Extreme w/ 2 SilenX 120mm Blue LED fans
(Lower fan is intake, upper fan is exhaust)
2 MSI 8800GT OC 512MB (w/ stock heatpipes + fan)
BFG Ageia PhysX Card (w/ MSI heatsink/fan)
4GB (4x1GB) G.Skill DDR1066 RAM
(1 set is 2.3v EPP, the other is 2.1v EPP)
Currently, the rig is in an ULTRA Grid ATX case with an ULTRA 700w Modular PSU.. I will be moving all components to my old Thermaltake Xaser 2 A5000+ case with a Thermaltake 850w Modular ToughPower PSU within the next week.. I just feel that will offer a bit better airflow and cooling, and the added power won't hurt either.. The current case has 1 120mm fan exhaust on the rear, and 1 120mm intake on the front.. The Xaser case has 2 80mm exhausts on the rear, and 2 80mm intakes on the front, as well as an 80mm fan in the side window..
I've overclocked in the past with Socket A and Socket 939 rigs with not too many issues.. However, as technology moved ahead, I got left behind.. There are SO many options in the overclocking realm with this particular setup, I don't even know where to begin.. As I'm typing this message, my CPU sits at 31 degrees, if that bit of info is any help..
Any and all info/advice is appreciated.. Thanks..
