A fan
BulletHole24
Can anyone point me towards a good case fan that is 80mm but smaller than 20mm in depth? One with blue LEDs would be nice, but not necessary. Antec would be nice, but also not necessary. I need one for a certain fan slot on my case where the standard 80x80x25 fan won't fit.
Off hand the only thing I can think of are the Zalman 80x80x15 fans. They're a great fan, but no LEDs, maybe you could put in your own :D
No problem. Just curious, what slot in your case requires a fan less than 25mm in depth? I've never seen something like that...
it's the A-Top XBlade. There's a fan slot on the right of the case (the side with no window), and i realized that when I tried to put a fan there, the side wouldnt close. that's when i realized i needed a fan that was smaller than 20mm in depth.
