So it was about time i got me a new computer. This time i would build be a real computer rather than a nintendo pc (http://members.aol.com/ramonintendo).
So here is the case i got from newegg (40$)
the usb ports i cut off and put on top
here is what it looks like after some good time spent with my dremel
better shot of the skull i cut out
the skull is the same skull i got from the fan grill
here i used some bondo to smooth out the gap in the metals. The reason why i did this is because i needed that little rise so that the usb ports wouldnt hit my top drive, also that piece of metal is the one i cut off the bottom front also. it all fit perfect
here is some painting, oh yeah thats the modders mesh on mnpctech
better shot of the paint
usb ports
you can see how misses the cd tray by a hair, i got lucky there
different view
closer shot
i was changing the leds that came with the lcd, there were green so i changed them to red
my fan work
you cant tell if they are on or off (quiet
fresh paint
i made that fan fit
my soul has arrived
some wireing
making the feet light up
wiring the cdrom drives
new computer, new "JERKER", way better than my last crap desk
the other side
red cathodes, ON!
cathodes off...
As for the actuall computer going inside, newegg is replacing the motherboard and video card for me since they didnt work, or else i wouldve been done with this thing. As for the actually case i touched it up with some paint to cover up those small scratches, when i get more done ill take more pics....let me know what you think, thanks
usb ports
different view
closer shot
my fan work
fresh paint
i made that fan fit
my soul has arrived
some wireing
the other side
red cathodes, ON!
cathodes off...
