9800 pro
I got an ATI 9800 pro 128mb overclocked to 430/350 and i feel i can get more out of it... its at stock coolign but i have a 80mm fan blowing fresh air from the outside an inch away from the gfx card onto the gfx card directly. Is this anuff cooling or should i get a vga silencer? what are the advantages of getting it
sounds good.. i wouldnt expect too much more out of the core, but maybe another 10mhz out of the ram.
Go to this site........ www.ocfaq.com find the E-die Gigacube 9800 Pro bios then flashed your card to it........ If you have the 8E-GC2A Samsung ram then your in luck.......I flashed mine and been scoring high on the ram 380mhz......the bios will let you overclock better..........
