9700 pro broke pushpins
rainmx
I have a 9700 pro and it was over heating ,so i took it out to check it and found that the pushpin had worn out and no longer heald the heat sink in place. I have heard that you could use screws and plastic washers to replace the pushpins, but i am not sure what size to use. Does anyone have any experience with this problem? Any suggestions or information would be appreciated.
