9600XT volt mod overclock.....HELLLP!!---->
tracerwilly
Edited to comply with all guidelines
I finally got the ThermalTake Giant III, and after reading the installation guide/review by Cornelioius0_0 and W1zzard's review on his site I made 4 mods to it and installed it. It runs real sweet and seems to keep the card at 30 degrees C. :eek:
That's all great ....but (and this is the reason I need help) here I am sitting with a 10K ohm resistor in one hand and a 4.7K ohm in the other. I checked all over the net, including Unoid site, and can not find a guide to volt mod a Sapphire Radeon 9600XT 256 meg card. No where on this card do i even have a 20 pin chip circuit. All are 10 or 8 pin, so i need help to figure out or tell me where i can get more info for this card? Thx.
I MEANT BACK TO THE HARDFORUM...as you can see i posted this yesterday. is there a problem with that ?
I think Kronchev was suggesting that since you seem to be only addressing Cornelius, that your question could have been asked via PM. The point of starting a thread on a public forum is to get a response from the public. If you only want to talk to Cornelius next time, that's fine, just keep in mind there is an easier way to do it.
While the thread had the name Cornelius0_0 in the title, this forum is called Overclocking & Cooling and is open to the general public as far as i can tell. That means if anyone OTHER than Cornelious 0_0 has a VALID response to help me with the issue that I addressed to start this post, they are free to express it. All of these subsequent posts are therefore just a valuable waste of time and resources.
tracerwilly said:
While the thread has the name Cornelius0_0 in the title, this forum is called Overclocking & Cooling and is open to the general public as far as i can tell. That means if anyone OTHER than Cornelious 0_0 has a VALID response to help me with the issue that I addressed to start this post, they are free to express it. All of these subsequent posts are therefore just a valuable waste of time and resources.
Understood, I'll try not to waste any more of your precious time and hope that you will do the same for me in the future.
