Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Ok .... Whats better from you peoples opinions on the SAPPHIRE ATI RADEON 9600XT Video Card, 256MB DDR, 128-bit, DVI/TV-Out, 8X AGP
or
ATI RADEON 9700PRO 128MB 8X AGP W/DVI TVOUT
Whats better to oc.. and what give out best overall performance.
The 9700 Pro will give you better overall performance - even at stock speeds - than even a maximally overclocked 9600XT. The 9600 series cards, including the 9600XT, are crippled at both GPU and memory interface level - the 9600XT has only 4 pipelines, versus 8 pipelines on the 9700 Pro; the 9600XT has only 128-bit access to its memory, versus 256-bit access for the 9700 Pro. Even the 500MHz core speed of the 9600XT cannot make up for its shortcomings.
That said, the 9600XT is a good midrange card. But why settle for midrange performance when a reasonable additional cost will give you so much better performance?
