Just received my 9600GSO from newegg yesterday and plugged it into my computer and It wouldnt post. At first I thought it was my power supply (using and older antec 430watt TRUEPOWER), and it didnt have the plug that plugs directly onto the card, so I had to use the converter and plugged in one of the molex connector, and figured out i needed to plug in 2 molex connectors. My question is, is it better to use 2 molex connectors from 2 plugs, or 2 molex connectors from the same plug? Or does it not even matter? My next question is which driver would work best for this card? Mainly for Counterstrike Source and COD:W@W. I installed the latest drivers 186.xx, but didn't see the control panel so i installed the 182.50, and they work good. Is there a better driver out there that might be optimized for these 2 games?
