my 'gaming' Mobo only has 2 9pin USB ports, and with my AIO/front USB hub and now my RGB connector, I've run out. can anyone recommend me a solid(stable) splitter?
EDIT: the typical 9-pin USB 2.0 header is actually two ports. So you could split that if whatever you have plugged into it isn't actually using both ports (i.e. it only has 4/5 wires instead of 8/9)
