Regarding the 8800GTS:
I want to run to one LCD monitor (via DVI) and also use the HDTV out (via the included component cable). I want to display the same image. What kind of impact does that have on the performance of the video card? I just want to be able to display the same thing on my TV.
Also, how long can you run component cables? Is there some kind of threshold you hit when you start to see deterioration in the signal? Basically I'm trying to run a poor-man's HTPC.
Thanks
Thanks
