8800GT upgrade?
dambrosioj
I bought a new 24" monitor the other day so I can have a dual setup with my HTPC
Also running a 1080p samsung HDTV as secondary display
I have a 7900GS card at the moment powering both, 2gb Ram, Vista Ultimate, All Correct Codecs, AMD 5400+
I can run HD 1080p video fine with the single monitor now that i have dual when i send the video to play full screen to the secondary display (HDTV) it stutters with the video. I want to be able to watch the video on my HDTV while still browsing the internet on my 24" is this possible?
Is this a video card issue if I would upgrade to the 8800gt would this solve this problem?
3850 would work for you
also some video cards actually has an output that has one HDMI + one DVI
Sounds Great!
I rather go with the ATI seems like a better card for my htpc due to the reviews
I was looking at some of the 3850's does anyone have a link to a good price? I would like to have a 512mb card and the 55nm if possible
Sounds Great!
Newegg's got a fair amount to choose from. When they're in stock.
