Hey everyone, well after trying somethings to figure out why I'm getting bad temps even with an XP-90, I came to the conclusion that I'm not having enough air going through my case. (I took off my side panel, and I was getting temps of 30-33C!
[compared to the 42C I get with it on]) So I'm going to replace the front 80MM fans, I can barely feel any air getting pushed through even with it on the high settings, and I heard with some doubled sided tape you can fit a 120MM fan in the floppy cage, so I think I'm going to do that as well.
Now on to my question, which 80MM fans should I choose? What do you guys recomend?
I was recommended these CoolerMaster LED(32CFM@25DBA) if I wanted bling factor (don't really mind) but I was wondering if thats really true because these Sunon(respectable company) has these fans (35CFM@30DBA) so I'm not sure what to go with? I was also wondering about the Zalman fans because they have a 5V adaptor which pushes 20CFM@20DBA. I'm looking to keep my stuff quiet, but I'm not very picky...
