80mm fan question
nomak
Im wanting to put a 80mm fan in a side panel on my case. Im wondering if there are any specs on where the mounting screw holes are from center of fan so can step them off and drill them in.. thanks...
I don't know the URL, but PimpRig has a nice fan template that you can print and use
thanks,, did a search on google for it and found it first try....
