8087 cabling issue.
Percy
So while trying to put together my file server I came across an issue. The first first cable plugged in won't be an issue. The second cable plugged in will hit the fan blade. I cannot mount the fan on the inside of the bracket due to using an E-ATX motherboard and it hitting the ram slots. Any of you know of a reliable angled 8087 to 8087 cables that might work in this situation?
It also wouldn't hurt to install fan blade guards on those fans, so if a cable accidentially hits them, it won't go inside and get chopped up.
I was thinking about fan guards... but I shouldn't have a problem with a cable hitting it. I'll look into it.
