7900x bumpin core boost and ACE on with Asus x670-p wifi
jarablue
Not sure but my shit is hauling ass with idle temps in the mid to high 20s and low 30s. No problems whatsoever. I can game all day without issue.
Is this normal? I enabled core boost and ASusCE in my asus bios. Didn't think this would run both of them on! Shit is bumpin yo!
Also I am on the latest bios for my asus x670-p wifi motherboard. These voltages seems high for a 7900x. Do they seem high to you? The core and SOC?
That 1.424 reading on you bios is inline with the one shown on the HWInfo.
If you're using custom water cooling, you don't have to worry.
I'm using Corsair H115i 280mm radiator and run 5250mhz using 1.28v on my ryzen 7500F.
The max temp for avx512 workload is 93c while for gaming it's only 50ish with wattage max 30w.
Power settings defaulted to High Performance with newest chipset drivers! Check that first.
