EQTakeOffense
- Sep 12, 2002
In terms of stability and the ability to overclock, which is the better chipset? I know one does SLI the other CF, but I want the best chipset to build the best computer I can.
It seems that the x48/x38 tend to be more stable, and overclock higher, and are better over all then the 680i/780i, but it seems that the 680i/780i are much more popular (maybe because of SLI?).
So, when it comes down to it, which is the better chipset, x38/x48 or 680i/780i?
I want to go SLI or CF, and depending on which has the better motherboards is the route I'll go.
