7800GTX question
axl2000
Is 7800GTX enough for 1280x1024 playing with new games? I can buy it for about 190US$ and don't know what 2 do...
Cpu: P4 3,2Ghz ---> C2D E6400 in about 2 months...
At that range for the monitor you specify...it should do pretty good. You will not get HDR+AA though.
General - how's you 7800gtx working with that A64 ??
1280x1024 = 1310720 pixels per frame
1440x900 = 1296000 pixels per frame
Does it mean that 19" panoramic LCD would be better ? I mean games would run a little bit faster?
i was running a 7800 gtx with a 1280x1024 monitor. it was fine for most games. after a change up to 1680x1050 it had trouble keeping up though...
Mine runs games fine at 1680 x 1050. But I paid $125. $190 is way too high, buy a 7900GS instead, it's faster OC'd.
It basically is. Performance is similar, too, although I think the 7900GT is slightly faster. $190 is a little too high when you can get 7900GT's for that much.
