Posted a related topic here: http://hardforum.com/showthread.php?t=1011206
I thought it was a problem with WoW since I had been playing COD2 all week at 445/1070 fine and actually got a nice little FPS boost for the mean time on myGigabyte 7800GT. Was going to go to around 470/1100 and then playing WoW yesterday I got BSOD related to video card. I thought WTF at first so I tried reloaded the drivers and loading beta drivers. Put the clock speed back to stock settings of 400/1000 and bam everything ran fine.
Then I tried an easy clock of 425/1050. I looped 3dmark and about 2 hours into the test I was greeted with the BSOD. Temps are great at around 44 C and never higher than 55 C when I had it at 445/1070 playing COD2, albeit not stable in other things.
Since the card is a little over a month I was debating sending it back. Granted the card does what it is suppose to do, but I feel no reason with the Zalman it should not be getting at least better than most other stock cooling 7800GTs. Was thinking about the volt mod, but then I feel that if the card can not do a 25 mhz core overclock on stock voltage, nothing would help it. Any suggestions? Thanks.
