7000A-Alcu on IC7-MAX3
with mine it reports 106F cpu and 82F system. I think the cpu temp is probably high by about 15-20 degrees.
Ehmm... celsius, man. Anyway, if you haven't noticed, most Abit boards REPORT higher temps.
The Unknown said:
"The Volume" what are your temps with the Zalman (7000CU) and the Abit mobo? :cool:
The Volume? Mkay anyway... not overclocked, 46c idle and ~58c load.
from me experience with my abit ic7-g, the cpu temp is between 8-12C off, reports it hotter than actual. that bios update thats supposed to fix it doesnt.
