amd_inside
- Jun 27, 2004
Hi,
I currently have the Enermax Noisetaker 470W. One feature is that it has a seperate cable for the video card.
My questions are:
- Is there going to be a 4pin to 6pin converter? I know there are those that will use two molexes to make one 6pin connector, but what about just one molex to one 6pin.
- If there isn't one like the aforementioned, would it be safe daisy chain? Connect a Y connector to the VGA molex, then the two molexes to the 6pin connector?
Thanks!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My questions are:
Thanks!
