6fire replacement?
Matija
Hi guys,
I'll be upgrading my old PC soon and since I'll finally be switching to something more modern than Windows XP, I need a new sound card. There are no new drivers for my Terratec 6fire.
I have some requirements, though...
* The card will be plugged into a Denon amp - I need quality analog output
* I have no need for 5.1, digital, or fancy sound effects and EQ
* For that matter, I don't want *any* internal resampling to xy kHz and qw bits going on
* RCA jacks would be very nice to have, and so would ASIO
* No stupid control panels and huge drivers that not only take ten seconds to load, but are required for the card to work
I don't know if such a card even exists in 2013.
Money is kind of an issue, but it's also not. Let's cap it at $150, since that'll probably translate to 150€ + VAT, and I don't want to spend any more than that.
Any ideas or recommendations?
Have you though about looking into an external DAC with a USB input?
It's basically the same thing as a sound card but it will sit outside your case and have it's own power supply.
Ah I just looked up that terratec and notice it's an external USB soundcard.
