TeleFragger
- Nov 10, 2005
Ok so I am getting ready to start modding my antec 900 case..
anyhow... I took apart an old tiger direct piece of crap case..
the case was silver and had 1 led bars run up and down on each side of the case...
so I took it all apart.. and apears to be just a led on each side of the clear bar....
so they work and work nice... however I want to put a toggle switch in and the toggle switch lights up too....
well since I took the led off the case.. they had a power plug... which has a black and red wire... thus ground and 5v....
the switch I wish to use was from my truck when I had my kc daylighter lights hooked up to them.... so they are 12v switches.... they are illuminating at 5v but dull.... so how can one tell if the led's can handle 12v? or is that just going to be a neigh??????
Thanks
~Jeff
Thanks
~Jeff
