good plan; IIRC, you can buy PS/2 connectors at radio shack.xonik said:I don't know your application, but I'll throw it out there anyway: the PS/2 ports also have a 5 volt supply.
By spec a USB port should only be able to provide like 2ma or or something like that without a proper USB device attached. Normally you'll be fine drawing more - but you have the potential to do some damage.fat-tony said:I'd definately go for game port over USB port. Should be able to handle more current.
most LEDs can be run at up to 20mA.STRESSTEST said:LEDs are rated at 20ma
The output control lines on parallel ports are open collector, pulled to +5V using a 4.7K or so resistor. You won't get any power from those...mattg2k4 said:Pin 9 on the parallel port is the 7th data pin.
To get +5v, use one of the active low output lines, such as pin 1, and any of the grounds, pin 18-25.
serial ports don't have a +5V line.
Signal State Voltage Assignments - Voltages of -3v to -25v with respect to signal ground (pin 7) are considered logic '1' (the marking condition), whereas voltages of +3v to +25v are considered logic '0' (the spacing condition). The range of voltages between -3v and +3v is considered a transition region for which a signal state is not assigned.
Logic states are assigned to the voltage ranges shown here. Note that this is a "negative logic" convention, which is the reverse of that used in most modern digital designs.
Most contemporary applications will show an open-circuit signal voltage of -8 to -14 volts for logic '1' (mark), and +8 to +14 volts for logic '0' (space). Voltage magnitudes will be slightly less when the generator and receiver are connected (when the DTE and DCE devices are connected with a cable).
And my day job involves designing this stuff.theshadow27 said:umm by rs232 standerd they are 5 volt buddy.
ps2 ports can by spec source 100ma
usb ports on powed hubs (including computer hub) can source 500ma
game port is also 500ma
lol i was looking to like up a keyboard with CCFL and EL but it turned out i didnt have enugh current... the point being that i reaserched all this stuff
