59x0 overclock/mods
ryuji
is voltmoding a 5900 worth the trouble/risk if it already does 500/900 stable
only problem with core is heat i think since it seems to run fine for a while n then slow itself down shortly after rivatuners temp graph goes past 100 C
going to get a zm80d-hp to remedy this
i may over volt the memory go get it past the 1 ghtz barrier
what are everyones comments on removing ihs..yes or no
