5900xt Questions
Wicked_Bass
I am looking at one to use until dec. for my rig is this an acceptabel card for decent framerates without super dooper detail.
Also should I get the 128meg or the 256meg card thanks Wicked
dont know about the card, i think it stacks against a 9600xt but dont know for sure
dont get the 256mb version, the extra memory is useless
If you get a good one like the eVGA or XFX and OC it you'll be able to get around 9800 pro performance. The eVGA and XFX's will hit close to 475/950 which is 5950 speeds.
I have a Gigabyte 5900XT but it doesn't want to clock very high. I run it at 440/800.
Looking at Gainward 5900xt overclock
BFG 5900xt Overclock
or xfx 5900xt which one do you think!
I would go for the XFX. I like Gainward and BFG but i dont think ither of them have the higher speed RAM the XFX uses.
I have a bfg 5900xt and it got 5774 on 3dmark 03 plus it works nice in all the games and stuff i use.
Wicked_Bass said:
what about what you suggested before!
xfx or evga which one?
Did i say eVGA? I'm sorry. I meant Leadtek.
Just look at both of them on Newegg and pick the one you like the most. They will both perform really well for a 5900XT.
