Well, the honeymoon was over fairly quick with a pair of 5870's. Was upgrading from a 4870x2 and the increased speed from the 5870CF was great. But these cards/drivers have issues. Now the disclaimer: I'm not a noob, system was stable before and after changing back to the 4870x2 even after the OS being hammered with installs, etc. (probably need to do a fresh install now).
System:
Issues:
Summary: both cards work in CF but only allow one display to be active in 2D and 3D modes; no extended desktop. Could remove one card and have 2x functioning displays in 2D with extended desktop and 3D modes (second display not accelerated like the 4870x2 - useful for showing TeamSpeak, etc during gaming). One card whines now after very little use, great...
Tried the 9.11 drivers first then the two beta's (beta 4 and 5) with same results as above. It is possible only card card is defective but which one? Frankly, after experiencing these issues first hand, and seeing the number of quality reports with so few in circulation, I have to wonder if ATI knows they have issues with the product.
Question: has anyone successfully enabled 2x displays for 2D use while having 5870's Crossfire enabled? Any ideas?
PARTIAL FIX: updated MB BIOS, formatted and installed final Win7 (was on beta 7100). Expect there was a problem first with the BIOS then with legacy registry settings from the older 4870x2 card. See below...
System:
i7 920 @ 3GHz
DX58SO w/ 6GB
850W PSU
X-Fi Audio
Windows 7
DX58SO w/ 6GB
850W PSU
X-Fi Audio
Windows 7
Issues:
- System resets hard when trying to select/deselect CrossFire with both installed, once the CF setting is enabled during install it could not be changed (attempt to changes causes hard reset after reset...)
- No dual monitor in CrossFire - not dual monitor accelerated - just simply having 2x displays enabled when not in games is impossible when both cards installed (tried all DVI connections on both cards CCC would 'see' the monitor when connected to the second DVI on the primary card but would not enable - system hard resets if 'extended' or 'duplicate' is selected
- Switcher noise from the card; buzzing-like sound started only after ~2 hours of use with one card installed; noise sounds like it is related to fan but actually comes from the switching supply on the board; can hear the pitch increase and get louder instantly when the 3D demands increase (this is the noise also often heard from bad / overloaded power supplies and mainboards)
