I own an XFX 5870, and am for the most part gaming with it on COC World at War. With full eye candy on, frame rates are excellent (usually >90fps; w/ Vsync off obviously), with dips only during missile attacks.
I've also been monitoring my quad cpu usage and gpu usage and temps. COC WAW gpu activity ranges from 70% to 99%...quite often it hovers up and down around 99% when there's alot of action and players logged on.
Temps on the 5870 during the high stress (activity ~ 99%, and full eye candy) can get up into the lower 80's C, with the auto fan usually running ~ 33%. Temps never go above 85C, where the fan would kick up into 37% (I'd actually like it to kick into 37% here). For comparison, setting the fan manually @ 36%- 37% keeps temps in the 70's C all time. Idle temps are good. All the above tells me the thermal paste on the stock unit is ok, as a good amount of heat is exiting the card.
Question, is it safe to keep the fan on auto, w/ the temps sometimes to often running into the lower 80's. FYI, the case air flow to the video card is excellent. And of coarse, if I lower ambient room temps, then all the temps discussed above do drop.
Is if safe to run the 5870 into the lower 80's for extended periods of time? Since this is what the card's bios settings allow on auto fan, I assume it must be safe? ..............Anybody been watching their 5870 temps in this detail?
Last FYI, in my own experience throttle begins @ 90C, and gets aggressive @ 95C.
