Hello,
My dad just recently purchased a 560 2win from evga. The comp starts up but no video shows and the fans on the gpu run. We bought the card to run on his old system and figured there would be some compatibility issues. Which issue do you think is causing the card not to run?
PSU is 520HX from corsair. I know the card probably needs more power but the reviews I read said it used about 330W plus whatever the rest of the comp uses (my dad's comp is not overclocked or anything so I figured it would be an extra 100-200W at most) and thought we'd be ok.
Mobo is a g33m DSR2 micro atx mobo. The PCI slot is 1.0 x16. I thought most 2.0 x16 cards were backwards compatible with 1.0 x16 slots.
Based what the comp is doing (i.e. is able to post and run but no video) what do you think the issue is? I'm hoping its a psu issue because if we were to update the mobo it would be a newer socket and thus require a new cpu and ram. Also, I think I read somewhere that the 2.0 x16 slots on the mobo provide more power directly to the card as well. I'm thinking it's probably a mobo issue... Thanks,
-Justin
-Justin
