5000 hr solid state capacitors?
Xenozx
So, I bought a asus p6t motherboard, its the vanilla, not the deluxe or anything. On the box theres a sticker that says
5000hrs VRM
100% japan made Solid Capacitors
now, i did the calculations, and that works out to a little more then 200 24/7 days.
Are they saying that this board is only going to last 5000 hr's, cause thats how long they expect the capacitors to last?
5000hrs VRM
Does it have anymore information on the sticker. Typically 5000hrs would be if the operating temperature is in excess of 105C.
i wish, but 2 places on the box it says the same thing :(
I just found out all their boxes say this, even the deluxe, and rampage.
Here is an article that kind of explains it. I feel better now.
http://event.asus.com/mb/5000hrs_VRM/
basically, if it was running at 105c, it would last 5,000 hours, at 65c, its 50,000 hours. I dont know why they would quote the 5000 instead of the 50,000....
seems dumb to me.
seems dumb to me.
It's a demonstration of the extreme cycle the caps can be put through at those temps. It's all marketing hyperbole.
