$500 upgrade
pclov3r
Higherend Gaming, Little Photoshop and watching movies.
$500 total budget Can be adjusted within reason of like $30
3) Where do you live?
95003 zip code
CPU, Ram, and Motherboard
Corsair TX750W PSU
Creative X-Fi Sound card
Noctua N9-U9B CPU Cooler
Intel X-25 V SSD
WD 1 TB Drive
NZXT Guardian 921 Case Mid Tower
GTX 275
9800GT
6) Will you be overclocking?
Yes, If Possible
2 22"
Soon
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Would like SLI USB3 and Sata 6 GB
Yes, Windows 7 64-bit
Need some suggestions. I was looking at upgrading to maybe Buldozer or Sandy bridge and 8gb DDR3-1600 MHz OR an I7-950 if the price goes down enough.
Must be an Asus motherboard board.
Also have plans for a GTX 480 or GTX 570 later on.
Right now I have a Q6600 8gb DDR2 800 MHz Asus P5Q-E MoBo
You may want to grab the RAM now, as it could go up in price in about a month or so:
$110 - G.Skill Ripjaws 2x4GB DDR3 1600 CL9 1.5V dual channel kit
Don't expect the prices of Intel's Socket 1156 and 1366 processors to go down with the arrival of Sandy Bridge. Intel has a long history of keeping the prices of its older parts static in order to encourage people to buy its newer parts.
If you can't wait that long, one of these two combos would be good enough for your needs:
$273 - AMD Phenom II X4 955 Black Edition + Asus M4A89GTD PRO/USB3 combo
$329 - AMD Phenom II X6 1055T + Asus M4A89TD PRO/USB3 combo
As a caveat, those combo deals expire at the end of the month/year.
