My barebone system SUPERMICRO AS-1042G-TF 1U with 4 6174 now running at 1.8GHz.
It has [H] bios and OC 10%, and was running for a couple of weeks at 2.4GHz. Cpus has passive heatsink and system fan speed was set to balance, because fulspeed was so noisy.
I did not check cpu temp accurately, just log in once a while through IPMI, and CPU1 temp was medium, other CPUs temps were low. Since 2 days ago I started to see TPF increased but I did not check into problem. Last night I had time to look at it and dmesg shows speed at 1800MHz. Is there anything I can set other than reflash original bios, or change CPU1 with CPU4, or rerun smocng.sh to make it run faster or at least at stock speed of 2.2GHz? Any help would be appreciated and thanks guys for the contribution to the science and progress, keep working hard.
