I've installed the AMD GPU Clock Tool and it does a fine job of adjusting my GPU speed beyond 790MHz. I've also used the trick to increase the fan speed bymodifying the CCC profiles. What I can't do is both at the same time. It seems like if I overclocking with the GPU clock tool I can't also increase the fan speed. I seemed to have got it to work once but can't repeat it. Is there any way I can overclock beyond 790 AND adjust the fan speed?
Where's my Riva Tuner support?!
