Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well Prescotts do tend to run hot. In an attempt to lower the temperature you could try reseating the heatsink with a high quality thermal paste and see if that helps. Also if the heatsink has been on there a while then maybe it needs cleaned? This is really all I can think of to lower your temps. Hopefully they help you
