WarHawk427
- Jun 20, 2006
I've had my 4400+ since January, and recently, i applied AS5, my idle temps before the AS5 seemed high 50'ish, now my temps now, after the AS5 are 46 idle /52 load, I had it over-clocked (to a 4800) and as soon as i saw the temp was a near 60 after battlefield 2, i decided it was WAY too high for my liking, so i brought it back to 2.2ghz, am i in need of a new heatsync?
my proc is getting excellent airflow so thats not the problem, the plastic card on the heatsync is off, and the heatsync is properly fitted, and i used a grain of rice sized glob of AS5...Any help is appreciated.
