40$ case tempered glass
Link to actual case:
https://www.newegg.com/Product/Product.aspx?Item=N82E16811353122&Tpk=N82E16811353122
Sounds like it has an air intake issue but can be fixed with some adjustments:
Cons: >airflow sucked originally due to the slits on the front of the case are mostly closed off, luckily this was fixed by taking the front off and using wire clippers to clip the tops of the plastic pieces blocking ariflow and then bending them back and forth to break them off
Says on sale for $55 with $15 rebate. Shows $60 for me with no sign of rebate, still not bad price. Tinted tempered glass is kind of a neg. for me.
Good looking case. I will keep an eye out for this next time I build a budget rig for friends, or family.
They copied my mod design, sorta. ;) Ordered one for a customer. I'll figure out the airflow, shouldn't be that hard.
