{bmf}CrackSmoke said:to bad mines OEM (grrr Dell)
Saeid said:I think the question should be:
Has anyone hit 4Ghz with the Intel's Retail HSF???
If so what is ur ambient temp... how many fans do you have in your case... what case are you using?!?!
Unknown-One said:Dude, I've seen one running at 7.0GHz![]()
krotch said:I have a P4 630 and I'm lucky that it's running at 3 ghz. I had to watercool it just to get it at a stable 52C temp.
Manuelj43 said:Makes ya wonder how the hell some of these people successfully OC their cpu while not knowing what "oem" means or stands for.
Just look at it this way...a product with no packaging. Same stuff, but cheaper b/c you don't have to pay for the packaging.
Jodiuh said:How's the mating surface? I ask because my 630 doubled as a friggin' shot glass. When I pulled off the hsf, I found only the sides of the ihs touching it!![]()
krotch said:Flat, cause I lapped it. I tried everything, until finally dumping it on the WC kit.
jmsandrsn said:Which Dell system do you have? You still may be able to overclock if it is Dim 9100, 5100, Gen4, Gen5, XPS 600, and some Dim8400's (newer ones that have 925XE chipset).
jmanlp said:I did a few searches but nothing is coming up, does anyone know where the thread is?
krotch said:I haven't tried OCing it at all. It's sitting at 52C idle. Course, under load it still sits at 52C. I'm thinking the cooling no longer is the issue and the mobo has bad sensors or something...
