I haven't seen anything like this posted before, but I could have missed it. Although this is really cpu related, I posted this in here as it's a more relevant audience.
While trying to narrow down the reason for certain games stuttering, I have found what I would call a flaw in 3DMark06.
3DMark06 and 3DMark05 displayed the same stuttering effect that I and many others have seen in games. I used those benchmark programs as they were easy and quick to test with.
Relevant System Specs:
AMD X2 4400 @ 2.64Ghz
X1900XTX & X1900CF (XTX @ 690/800)
2x 1G Ballistix @ 240Mhz 2-2-2-7 1T
DFI RDX200
Fresh reinstall of XP-SP2 all updated.
The only cure for the stuttering effect in 3DMark from this excellent thread was setting the affinity to one cpu core. It was after looking at the scores more closely I spotted something different.
Both cores being used in 3DMark06:
SM2.0 Score - 4100
HDR/SM3.0 Score - 4328
CPU Score - 1575
Total Score - 8419
Only one core being used in 3DMark06:
SM2.0 Score - 4118
HDR/SM3.0 Score - 4474
CPU Score - 1026
Total Score - 7266
Nothing wrong with that you may say, as the first (and higher) cpu score is using both cores, so the score should be higher. But that extra cpu (flaw) is hurting 3D performance as well as killing the overall score. However, the main flaw is that it's not utilising the cores correctly because of the stuttering in visual quality when both cores are being used - just like in many games.
So much for being optimised for multi-cpu's!
Of course, it could be my system that's causing this, but I doubt it. Go on, try it yourself!
DFI RDX200
SM2.0 Score - 4100
CPU Score - 1575
Total Score - 8419
SM2.0 Score - 4118
CPU Score - 1026
Total Score - 7266
