3D mark 05 Question
Arcygenical
While I know 3Dmark isn't the BEST way to benchmark your computer's graphical capabilities, but I'm wondering what settings everyone uses when they do choose to use this program (version 2005)?
Anti-Aliasing?
Anisotropic filtering?
Resolution?
And finally, which tests? GPU, CPU and the tests for specific capabilities such as line drawing?
1024x768 full stop...no aa/af etc
if you have the full version just run the whole thing..its a good way to test your stability...if u dont have the full version then its just as feasible just run the 3dmark and itll only give you a graphics score and not a cpu score...
As I have the whole version, would running all the tests produce just a higher score than GPU only tests?
no...it gives you the all the scores seperately
Arcygenical said:
Awesome dude, thanks alot :).
nps...ask me for more help if you want...btw for 3dmark05 you only use your graphics scire you dont add it to your cpu score like in 3dmark06 :p
