Interesting, how do they prevent the user from seeing the flicker in the glasses.
3D shutter glasses have been around for a long time before 120hz LCDs. I used to have a pair of eDimensional ones for my CRT (which I used to run at 100Hz but there was still noticeable flicker) They only started coming back when 120Hz LCD screens came out and I thought this was finally fast enough to eliminate the flicker. If it's possible to do shutter glasses without flicker with under 60Hz then why couldn't they do it before?
They do flicker, but it depends on the brightness.
PS: With CRTs, you also have factor in the black period between frames
