nature1ders
- Jan 25, 2013
What do you think of 4.3 at Core Voltage 1.150?
How long am I supposed to run Prime95 for because I use to run it 24 hours on my old AMD processors or longer but this thing has a max temp of like 83C with these settings, I kinda don't wanna run it 24 hours at that temp.
Using 4.2 is mid 70's, like 74C full load with 1.120 but I'm not sure it makes a big difference from 83C full load, what you guys think?
I do have the Evo 212 sooooooo I mean I reseated over an over and get same temps basically.
I was going to use offset voltage but it makes no sense and I don't think would lower temps any, I mean why not just set the max voltage and leave it at that?
AMD has p-states, but this Intel how could I even test offset voltage to ensure stability at each state. Anyways bye
