3500/3800 Overclocking "ceiling"?
Mincemeat
I have a 3500 currently that is running on an A8V mobo @ 2.5GHz stable and at 36C for temp constant. I want to know if others have been able to get to 2.6GHz or above with either the 3500 or 3800. Stability on my comp is fine so I think I can push to 2.6, but I wouldnt try any higher unless some people here have had success doing so. Speask up if you have one of these and OC them. Thanks.
