wrangler said:Being lazy I guess (tried looking it up but didn't find anything) but this thread begs the question:
Is there a power supply that has a 24 pin power connector (native, no 20-24 converter) with greater than 30 amps on the 12v rail that provides the pci-e graphics card connectors for sli (no 4 pin to pci-e converters wanted).
I still hear a lots of people in love with single 12v rail with lots of amps and I think I tend to agree. But I understand that the power is cleaner with dual rails and it prevents the 12v rail to the motherboard from being subjected to the high and low sudden current draws that video cards can give.
All of the 24 pin power supplies with pci-e connectors I can find are dual rail.
1 day away from buying Antec Truepower II 550 if I can't find giant single rail 24 pin, pci-e and sata ready.
I'm with jonny.jonnyGURU said:Of course there are.
Your PCI-e card(s), drives, fans, etc. won't need as much power as what one rail of a quality, substantial, dual rail PSU is capable of providing.
I used to be on the single rail bandwagon too. But the technology is too expensive to make a single MOSFET that is capable of > 30A and still provide clean, cool, stable and efficient power... except for the Turbo Cool 510. Dead serious. Not even the OCZ 520ADJ because even that PSU starts to wiggle a little over 30A.
The new EPS version as the newest mobos will require it.wrangler said:So, I should go with the TPII 550 EPS 12V version? I thought those were for servers only. Can I use one with a regular ATX board without having to mod it in any way? I looked at the specs and they are the same except it seems to have an extra connector for server boards. Also, it has 2 80mm fans instead of the 1 120mm.
